Thanks for the tips Alex
Spectacular
._________________________
Originally posted by XelderX View PostAwesome. I have played with the Accel Enrichment a little, but it probably does need a lot more work. The only real "tuning" I did was on the dyno and after getting the A/Fs-timing in the ballpark we got stuck trying to fix a stumble on a very specific section of the table. I'm hoping the clean injectors will solve that issue as we couldn't tune it out.
what would cause a high idle with stock components
i replaced my iacv with one from a sohc tb and idle was fine for a few months now its back to idling at 1000 and sometimes if it wants to it will go down to 800
the mx3 also has this problem but its 900-1000 all the time i wont know whats causing it until i remove the safc2
If you think closed loop idle is good now, wait until the stuff that Ken (the lead developer on the MS2/Extra code) and I have been working on for the last year or so... It's lightyears ahead of where the current code sits. (partially because there's a math error in the current release code )
It's basically a complete rewrite and makes the closed loop idle much more responsive as well as stabler than it was before.Ask me about engine management!
Originally posted by matt_fulghum View PostIf you think closed loop idle is good now, wait until the stuff that Ken (the lead developer on the MS2/Extra code) and I have been working on for the last year or so... It's lightyears ahead of where the current code sits. (partially because there's a math error in the current release code )
The tuning and fiddling time to perfect MSII code on the platform is what is discouraging me a little since I know how long it took to work out the bugs with MSI.Last edited by Lex; 01-16-2009, 12:49 AM.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
I loaded Saturday the MS2 extra january29 code and it has some nice features such as idle spark advance with load (when you turn your heater or defrost on) and supposedly a better closed loop idle control, that I couldn't figure out in the 5 mins I had. Will try today but I do like the timing advance idea, helps keeping idle where it should under load. I also tried the cranking at different temperatures map and it helpes alot with hot starts. Lots of tunning ahead.
