What is a spark diode and a spark jumper? Are you checking it at the coil or at the disty or at each plug?
Ms
I lost spark on my MS a while back,it was brutal to diagnose,i tried everything.it turned out i had to reload the MS firmware on the processor,it somehow went corrupt.Car was running and died,wouldnt restart.Im not sure why it happened but its been fine since the reflash.The only thing i lost was spark-out.Powered by ACME
that information can be found at http://www.bgsoflex.com/megasquirt.html
under the assembly guide for the respective version your running.
you can read it over to get a feel for how hard you think it is.Ask Lex before doing this as he is working with you.Powered by ACME
The software is fine ... he sent it back to me and it fired right up so I wouldn't start there. Randall can you get another datalog of the car cranking? Last time the Megatune software was not quite setup right on your laptop for logging.
Something is intermittently failing (I am guessing intermittent short or open circuit in the wiring) here since the car starts sometimes and it ran for a while.
Originally posted by Lex View PostThe software is fine ... he sent it back to me and it fired right up so I wouldn't start there. Randall can you get another datalog of the car cranking? Last time the Megatune software was not quite setup right on your laptop for logging.
Something is intermittently failing (I am guessing intermittent short or open circuit in the wiring) here since the car starts sometimes and it ran for a while.Powered by ACME
Also Randall, before giving up on this, I strongly recommend tossing in a known working factory ECU and seeing if that works. Having tested the MS and having found nothing wrong, I am afraid you'll have the same problem with a factory ECU.
Let me know what you find out, I know this is very frustrating.
speaking of the ms, is it supposed to be so unresponsive? Everytime I start it, I end up having to shut my laptop down to get the ms to shutdown.
Example, I attempted to start it, went in and checked my email, left it hooked up to the computer but the ignition was off, ms was open. Then when I went back out and tried again to start it, the ms light would not turn on and the laptop would not recognize that I had it plugged in..
