Ok here's the deal, I'm buying 1. Whoa whoa relax. Lol. I know some of you are saying "that's a band aid" or "didn't you just tell stylinwagon(sp) that he shouldn't be running 1?". Well yes I did say that and do believe he bought that to use as a band aid.
Here's the reasoning in me buying 1.
1: I want a fuel gauge to keep an eye on the pressure
2: When I run the bigger turbo and bigger injectors I can adjust it slightly so I do run rich. I say this because I feel I will.
It will be set at the n/a psi for this current setup then when the new setup goes in I will probably bring it down to gtx fpr psi status. That should do the trick.
Voice out good or bad about this. Keep in mind my reasoning.
