My only consideration towards E85 was for a track only car with boost and a good dyno tune. Even then the biggest benefit would be the tax credit :p
Any one else running E85 in there BP/ BPT
Originally posted by BlackMazdaMx-3 View PostYeah i put it in and then drove right down the street and added fuel. i have a innovate Lc-1. It was at 18.1 when i put it in when it was previously at 14.7. So i added about 30% more fuel and now idle is at 14.7 again and wideopen back at 11.4. The lc-1 reads the same regardles of fuel type because it uses lambda. That stinks that you cannot get E85 its nice. I never even thought about it till one of my friends that runs E85 said why dont you run it you are only at 50% duty cycle on them injectors lol.
just did a quick search and found some of the info i read before http://forums.turbobricks.com/showth...=73061&page=10
Fuel ........................ AFRst ........ FARst ....... Equivalence Ratio ... Lambda
Gas stoich ................ 14.7 .......... 0.068 ................ 1 ................... 1
Gas max power rich .... 12.5 .......... 0.08 ................. 1.176 .............. 0.8503
Gas max power lean .... 13.23 ........ 0.0755 .............. 1.111 ............. 0.900
E85 stoich .................. 9.765 ....... 0.10235 ............ 1 ................... 1
E85 max power rich ...... 6.975 ....... 0.1434 .............. 1.40 ............... 0.7143
E85 max power lean ..... 8.4687 ...... 0.118 ............... 1.153 .............. 0.8673
E100 stoich ................ 9.0078 ...... 0.111 ............... 1 .................... 1
E100 max power rich .... 6.429 ........ 0.155 .............. 1.40 ................ 0.714
E100 max power lean .... 7.8 .... ...... 0.128 .............. 1.15 ................ 0.870Last edited by 1992tracerlts; 05-13-2009, 12:08 PM.sigpic
I know that the A/f ratios are different the lc-1 reads lambda so you tune for the same number regardless of fuel type. Trust me the tune was lean as hell when i first filled up on E85. I can switch the lc-1 to read alcohol afr but much simpler to just leave it alone. I have 600cc injectors,aftermarket rail and regulator. The factory fuel hose should be able to take the e85 when they engineered the hoses for 10% ethonol they over enginered it. Should be fine my friend has been running e85 on his talon for quite a while with no problems. I guess we will see. Im useing a jns knock sensor kit that my buddy has to verify no knock. It has quite a bit more power already and havent even hit the knock threshold.sigpic
1993 Mazda Mx-3 RS Black 300hp 330tq Mustang dyno, vf-10/vj-20 hybrid 26psi, Megasquirt Tuned on e85
1/8 mile 8.50@89 2.3 60' Parted out and missed!
1993 Mazda Mx-3 RS Blue Bp turboed VJ-20 16psi, Custom vj-20 inlet pipe, Custom 2.5 front mount intercooler, Custom 2.5 downpipe to 3inch outlet side exit exhaust, Rx-7 460cc injectors, Tuned on E-85 with Ems Pro, Corksport front / Rear strut tower brace and H&R lowering springs.
1\8 mile 8.81@82.66 still at 2.1 60'. Parted out
2004 Volkswagon Jetta Gli 1.8t Eurojet fmic,3inch downpipe to 2.5 cat back,apr stage 2 software, cold air intake and turbo inlet pipe and St coilovers slammed to the ground.
Sold and missed!
2012 Volkswagon Jetta S 2.0 8v Custom Cold Air intake, Raceland Coilovers, BFI Torque Mount Insert, Audi S4 Wheels, low and slow.
Daily driver
meh, i like economy when im not beating the piss out of the car. i'll stick to my petrol thanks---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by nerd racing View Postthanks for the new sig quote!
Wow, my wideband is not wide enough to tune E85... I get between 10 and 20 for A/F.
So since E85 you have to have bigger injectors and dump 42% more fuel in, which works out to be the same... why would anyone be using that? Is it more for the less chance of detonation? Cause you're not using less gas but just a more "environment" friendly gas.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
Originally posted by Shades View Post
Damnit, I'm just giving away sig quotes... you and Turpro. LoL...
So since E85 you have to have bigger injectors and dump 42% more fuel in, which works out to be the same... why would anyone be using that? Is it more for the less chance of detonation? Cause you're not using less gas but just a more "environment" friendly gas.sigpic
Depending on composition and source, E85 has an octane rating of 100–105[12] compared to regular gasoline's typical rating of 85–93.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
What aboot a 50/50 mix of normal high octane with E85?
Member of MX-3.com
why?
then your target AFR would depend on the exact mix you happen to be running... which will be hard as hell to controlEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
yes it is, you would basically leave the wideband calibrated for gasoline and tune it to the same target air fuels as you would if you were running gasoline. say you pour in e85 and tune it to 11.5 on your wideband your real afrs are going to be somewhere in the high 8's or something like that. does that make sense
its kinda confusing.. anyway just leave everything calibrated the same and tune it like you would normally with gasoline and you'll be fineLast edited by fastiva604; 05-14-2009, 10:38 PM.'88 mazda 323 GT
stock b6t, k&n cone filter, 2 1/2 turbo back exhaust, vf11/vj11 turbo, conquest intercooler, bosche bypass valve, magnecore 8mm wires,turbo xs dual stage boost controller, el proto ecu mapped for 18 psi and 8000 rpm.
Originally posted by fastiva604 View Postyes it is, you would basically leave the wideband calibrated for gasoline and tune it to the same target air fuels as you would if you were running gasoline. say you pour in e85 and tune it to 11.5 on your wideband your real afrs are going to be somewhere in the high 8's or something like that. does that make sense
protégébob Give me a call some time this weekend and i will come on over to CB. Im usually over on broadway on friday nights at the sonic. Ill Pm you my number.sigpic
Sold and missed!
Daily driver
ya , ya, old thread, bla bla, hows the system holding up? ill be tuning for e85 soon as i get ms in.... what ms are you using, care to take screen shots of your fuel and timing maps for something to go off? any other info you learned you care to share with us??92 protege lx-
94 protege lx-
Originally posted by yunvmyegt View Postya , ya, old thread, bla bla, hows the system holding up? ill be tuning for e85 soon as i get ms in.... what ms are you using, care to take screen shots of your fuel and timing maps for something to go off? any other info you learned you care to share with us??
Fuel system is still holding up just fine. Walbro 255 pump, stock lines, m-tuned miata fuel rail, 600cc deatschwerks pnp injectors, aeromotive fpr.
I am useing a ms1 extra code, with vaf delete and idle control.
I have not have any problems with the car since i switched to e85.
Here are My fuel and timeing maps my car makes 22psi max boost. They may or may not work with your car it should get you close tho.
That is a dyno tuned fuel map for my car. Ignition was all done on the street. Made 300hp and 330tq on this map.
It will run pretty lean during cruiseing conditions helps with fuel mileage.
Just zoom in to 200% to see the maps%.
Good luckAttached Filessigpic
Sold and missed!
Daily driver
