I've read that E85 is harsh on fuel pumps also...
Any one else running E85 in there BP/ BPT
._________________________
sweet **** man, atleast i have something to start with, your pretty close to my set up aside from i have a vf8 instead, and some web cams.... but im on a stock na block atm... and as far as fuel parts, im thinking of making new bigger lines, and possibly a helper pump inline with the other one to keep pressure up. im goin to get another walbro and toss it in my glovebox just incase i ever need it, theres always ones local for like 50 bucks....Last edited by yunvmyegt; 01-12-2010, 07:43 AM.92 protege lx-
94 protege lx-
I have not had anyproblems with anything in my fuel system at this time.
I also am geting 25mpg with my lean burn tune thats combined city/highway and in boost quite a bit. Dont know yet what i can get just going down the highway.
It gets about 20mpg in town driveing only.sigpic
1993 Mazda Mx-3 RS Black 300hp 330tq Mustang dyno, vf-10/vj-20 hybrid 26psi, Megasquirt Tuned on e85
1/8 mile 8.50@89 2.3 60' Parted out and missed!
1993 Mazda Mx-3 RS Blue Bp turboed VJ-20 16psi, Custom vj-20 inlet pipe, Custom 2.5 front mount intercooler, Custom 2.5 downpipe to 3inch outlet side exit exhaust, Rx-7 460cc injectors, Tuned on E-85 with Ems Pro, Corksport front / Rear strut tower brace and H&R lowering springs.
1\8 mile 8.81@82.66 still at 2.1 60'. Parted out
2004 Volkswagon Jetta Gli 1.8t Eurojet fmic,3inch downpipe to 2.5 cat back,apr stage 2 software, cold air intake and turbo inlet pipe and St coilovers slammed to the ground.
Sold and missed!
2012 Volkswagon Jetta S 2.0 8v Custom Cold Air intake, Raceland Coilovers, BFI Torque Mount Insert, Audi S4 Wheels, low and slow.
Daily driver
25mpg is what i get with mixed driving on 93 octane, so thats really not bad at all.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
I just tried e85 in my bp turbo'd with just the gtx computer. It doesn't react as well to the e85 than it does to 93 pump gas. I can slam it after 4 grand with just premium gas but with e85 i have to half throttle it. I just did this to try it out but i don't really see whats the use when you don't have megasquirt.Cincinnati, ohio Bengals for life
"Who Dey"
You cannot run E85 without a megasquirt or some other way to tune it. also bigger than stock fuel injectors are needed.
on a stock computer the arf will be way to lean and the car will not want to drive.
Also it can detonate due to the afr being around 18 to 1
E85 can help you make more power on the came setup due to being able to run more boost and more timeing. Can even help at the same boost due to increase in timeing alone.sigpic
Sold and missed!
Daily driver
A con for e85 I did not see is its “shelf life” ethanol is an hygroscopic meaning absorb water rapidly. This gives it about a 90 day shelf live in areas were ethanol is low in demand. Or those that cannot access it routinely. Thinking you can “stock up” and store e85 not the best idea..
For those that do not have e85 available or do not want to put up with the cons of it,,,
Methanol Injection is also a great route,, Inexpensive and very manageable on a regular basis. Just a thought…
Mx-3 Kl Turbo (Under the Knife Once Again)
94 Rx7 All Stock Montego Blue Touring Model
93 Lx
Yeah that also works. I just like e85 due to just haveing to fill up the tank tune and drive. No nozzles to clog or extra tanks to fill and keep an eye on.
There is a good demand here for e85 so shelf life does not come into play. But it could deffinitly cause an issue.sigpic
Sold and missed!
Daily driver
Originally posted by BlackMazdaMx-3 View PostJust wondering if any one else is running E85. I just filled up and tuned the car to run on it with the megasquirt. So far im likeing it. Still need to up the timeing more. E85 is 105 octane at $1.56 a gallon. Im only at 19degrees of timeing at 16psi or boost no detonation. I think with the E85 i should be able to run quite a bit more timeing. Probubly not much more boost tho on the stock bpt bottomend.Aku belly
^ still a cunt hair cheaper then 93 for a higher octane.
quite honestly it would be a badass thing for those track days. but short of that its not nessicarily a better route---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Yeah its not the 93 i compare it to.
I compare it to 100 octane is also around $10 a gal here. Because i would be running that if i was not running e85
E85 has went up some but its still just over $2 last time i filled up.
Still much cheeper than 100 and its higher octane.sigpic
Sold and missed!
Daily driver
Im building my new setup for E85, however i will prob make a mix of 85 pure ethanol and 15 VP109, should make for a good mix.
Heaps of guys mix fuels over here with decent results, as long as you mix even you dont have a drama, batch's are fairly consistant especially when you mix your 15% with a race fuel.
Or you could mix 80 ethanol and 20 methanol, but then you have corrosiveness issues to worry about, would have to run a plastic fuel cell
