Just wondering if any one else is running E85. I just filled up and tuned the car to run on it with the megasquirt. So far im likeing it. Still need to up the timeing more. E85 is 105 octane at $1.56 a gallon. Im only at 19degrees of timeing at 16psi or boost no detonation. I think with the E85 i should be able to run quite a bit more timeing. Probubly not much more boost tho on the stock bpt bottomend.
Any one else running E85 in there BP/ BPT
1993 Mazda Mx-3 RS Black 300hp 330tq Mustang dyno, vf-10/vj-20 hybrid 26psi, Megasquirt Tuned on e85
1/8 mile 8.50@89 2.3 60' Parted out and missed!
1993 Mazda Mx-3 RS Blue Bp turboed VJ-20 16psi, Custom vj-20 inlet pipe, Custom 2.5 front mount intercooler, Custom 2.5 downpipe to 3inch outlet side exit exhaust, Rx-7 460cc injectors, Tuned on E-85 with Ems Pro, Corksport front / Rear strut tower brace and H&R lowering springs.
1\8 mile 8.81@82.66 still at 2.1 60'. Parted out
2004 Volkswagon Jetta Gli 1.8t Eurojet fmic,3inch downpipe to 2.5 cat back,apr stage 2 software, cold air intake and turbo inlet pipe and St coilovers slammed to the ground.
Sold and missed!
2012 Volkswagon Jetta S 2.0 8v Custom Cold Air intake, Raceland Coilovers, BFI Torque Mount Insert, Audi S4 Wheels, low and slow.
Daily driverTags: None
2.69 still isnt that bad. the last time i put fuel in my 95 it was nearly $5.00 a gallon....
i'd run E85 in a heartbeat, but we cant get it around here. you know you have to tune for different (richer) AFR's with that stuff right? lambda is at a much richer point.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Yeah i put it in and then drove right down the street and added fuel. i have a innovate Lc-1. It was at 18.1 when i put it in when it was previously at 14.7. So i added about 30% more fuel and now idle is at 14.7 again and wideopen back at 11.4. The lc-1 reads the same regardles of fuel type because it uses lambda. That stinks that you cannot get E85 its nice. I never even thought about it till one of my friends that runs E85 said why dont you run it you are only at 50% duty cycle on them injectors lol.sigpic
Sold and missed!
Daily driver
What stations carry e85? This might be exactly what I need for the 460cc injectors and my tiny turbo.1993 Protege LX-Midnight's shadow SOLD
there was an official statement from mazda released in austrailia about was cars were E85 compatible based on the materials used in the motors and the various seals. the BG/BP vehicles were not listed due to incompatible seals.
Keep an eye out for any leaks and deteriating rubber seals while running E85 and replace them ASAP.
also tell us which ones broke down so we can run alcohol based fuels too"Discontent is the first necessity of progress."
Originally posted by therieldeal View Post2.69 still isnt that bad. the last time i put fuel in my 95 it was nearly $5.00 a gallon....
Originally posted by MD323 View Postthere was an official statement from mazda released in austrailia about was cars were E85 compatible based on the materials used in the motors and the various seals. the BG/BP vehicles were not listed due to incompatible seals.
The ethanol does some nom nom nom on certain things.
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
psshh fuel mileage?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
oh, well yeah.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
