You have to set your rev limiter settings properly as well. Try cutting out more ignition events.
Yet another MS problem
Originally posted by Lex View PostYou have to set your rev limiter settings properly as well. Try cutting out more ignition events.
Also, I have to start my car several times for it to barely idle, and if i don't keep my foot on the gas and hold it at 1500+ rpm for about 30 seconds it will die on me. I think my warm up values are adding too much fuel. a/f's are between 9-10 when warming up.Create your own VB Gallery here.
Decrease WUE and increase ASE. Cranking should give you about 10 AFR, and then once it starts, it should slowly ramp up to 13.5-14 and warm up at that AFR. WU is a PITA to tune because if you change your ve table later, you'll have to retune WU. Also, set your wu rpm to be higher, it can't really wu properly at 800 rpm
i hate tuning WUE. mine is largely untuned, i just let the car idle and warm up before driving it, otherwise the AFR is all over the place lolEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Mine is a daily driver so I have to tune cranking, ase and wu if I want it to start at -20C every morning during winter. For now, it's tuned down until 0C and it runs well, I just wait 30 secs and drive it, easy on the throttle and no boosting. Below 0C, I'm pretty sure I'll need to add more fuel, last year I had lot's of trouble starting it in extreme colds. At -20, you need like 400% cranking, 150% ase and 200% warmup, and a good 2-3minutes of idling at 1800-2000 rpm lol.
thanks for the advice. but i have MS1, so i input voltages not percentages. i am gonna change my WU table to more of a 360cc table to see if that helps. also, once the car fully warms up, it idles correctly, but until it fully warms up it's idling low cuz of too much fuel.Create your own VB Gallery here.
