Kia is already set up that way. Coil on plug. I'm really looking for something with more aggressive fuel and timing maps. I almost have it going with the Kia ecm and harness. Unless it totally sucks I will probably just use that. But if the mitsu thing works better,doesn't make me pull my hair out, and doesn't cost zillion dollars, I will try it.
fe3 tuning?
The Kia uses a cam sensor, in conjuction with a crank sensor mounted in the bell housing, it picks up on a slotted ring around the flywheel. Its a ****ing **** of a setup to use, becuase you have to 1. Use a kia flywheel, and 2. find the exact spot to mount the sensor in the bell housing. I would not recommend doing it because there are better options.
Like Ryan said, early 90's Mitsubishi Galant management works. They use a cam sensor only, and it is identical internally to a Mazda distributor. So you can just put a distributor in with no cap on it. Wire up the Mistubishi loom to it and it works fine. They use two dual post coils, you can either use them, or wire it up to stock Kia coils.
If you have the smarts to tear down, strip and rebuild a wiring loom, I would highly recommend using the Mistubishi gear.
i have to use the kia flywheel because the crank has 8 holes instead of the standard 6. i have it in the garage already. i have also already stripped the kia harness and removed all unnessary circuits, ie: evap solenoid, and such, i can start the truck easily with this setup. i will do some more research. also i dont know if the maxda disty will fit in my application with or without the cap. truck is rear wheel drive. i will have the motor in in a few short weeks and give more progress then.I am an idiot.
I am building a fwd racecar.
1 good whack with a BFH & it'd clear even better---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
