i know they came with a coil pack and not a disty, but wiring wise whats the difference? im goin to look into this and would like some thaughts....i think the ecu fires them, maybe ill see about runing this on ms after i get it in...
whats involved in using this set up?
i know they came with a coil pack and not a disty, but wiring wise whats the difference? im goin to look into this and would like some thaughts....i think the ecu fires them, maybe ill see about runing this on ms after i get it in...Last edited by yunvmyegt; 01-03-2010, 08:15 PM.92 protege lx-
94 protege lx-
are you a thinker, or a believer?Tags: None
You need 2 or 4 ignition drivers, can't do that with the stock ECU. I'm running these in wasted spark mode with MS and TBH, they suck. At first they seemed to work well at low medium boost and I was running 0.038 gap but at high psi (above 19) on the VJ23, I still get occsional spark blow out with a 0.030 gap. They are maybe better than the crappy miata coilpacks and stock coil but still not worth it, usual toyota stuff only good for fuel efficiency. They don't have enough stored energy and the voltage is still 37KV so you can't open up the gap. You get rid of the plug wires though so that's nice. If I were to redo it, I wouldn't bother.
Just send your unit back to Alex so he can do the final touches then lol-Jack
I set my MS up to work wasted spark and I've got some COP's off of a Millenia that I'll be puttin in this winter. If your gona run wasted spark you are also going to need a way to trigger it. I ended you going to the junk yard and finding a 4-2 cas wheel from a mitsubishi that was wasted spark. Then just replace the stock one behind the rotor.
94 Protege LX: HX-35, Megasquit, ect...
98 Subaru Legacy GT-DD: 1 inch lift, and all the standard N/A stuff.
ya im not even sure what im goin to do with the coil pack idea yet now, who knows..lol... if itld get over 5 damn degrees here id go outside and toss the damn ms in just to try and get it running , id like to start playing with it ....92 protege lx-
94 protege lx-
the V6 guys drive coil packs with MS im fairly sure you cn do wasted spark COP with the MS with some modding, im currently looking at (after the car is running on ms) sequential injection on a V6."Discontent is the first necessity of progress."
