What VAF are you using again? I'm almost wondering if your adjustments to the VAF you're using brought it so far out of spec from what the GTX ecu was "expecting" that everything freaked out.
Rx7 vaf/fuel-cut
Rx7 vaf1993 Ford Escort GT-T
1992 Mazda Mx3 GS((Parting Out))
1994 Honda Integra LsVtec-Sold
1984 Toyota Corolla SR5-Sold
1983 Ford Ranger-Sold
My Turbo Escort GT build thread
My HUGE f/s thread. Go buy!!!
Myspace yooo
Originally posted by drewhall07 View PostRx7 vaf
1) How close is this VAF to the GTX VAF? (That is the ecu you were using, right?)
2) Did you try the GTX ecu with the RX7 VAF in stock adjustment?
This all seems like it's pointing to the ECU or the VAF, and i bet it's a combination of both. I HATE flappers with a passion for this very reason. Yeah, they're safe, and can do a lot of adjustment for the person that doesn't want to get too into it, but they're such a friggin' pain in the ass.
Also, what does your wideband show during cruising or idle?
Okay I have a question. I just read something that intrigued me. Someone said that a vaf can max out in hertz and then it tells the ecu to cut fuel. What does that feel like? Does it make the engine BUCK or could that buck be detonation? I guess my question is is there a way to unplug something or cut a wire in the vaf to eliminate fuel cut from happening at 15psi if my vaf is being maxxed out?
Maybe this is why we so many of us with bp26 ecus and u-code or b-code vafs are getting this boost cut/ fuel cut/ bucking at lower rpms under high boost levels? Could we be maxing out the vaf's? I would assume it would be easier to max out the sweep on the vaf door if the spring is tightened but we are loosening the vaf in most cases.
I just read somthing interesting:
http://www.machv.com/fuelcut.html
http://www.streetrodstuff.com/Articl...ion/Page_5.php
I think I can fool the ecu and vaf with the 460cc injectors if I tighten the vaf spring at idle. I think the ecu is just not capable of supplying the necessary fuel at lower rpms with the 330's and the vaf tuned for the 330's. If the 460's are in there and the vaf is tightened accordingly wouldn't it fool the ecu and keep fuel cut at bay?
Originally posted by cis2711 View PostOkay I have a question. I just read something that intrigued me. Someone said that a vaf can max out in hertz and then it tells the ecu to cut fuel. What does that feel like? Does it make the engine BUCK or could that buck be detonation? I guess my question is is there a way to unplug something or cut a wire in the vaf to eliminate fuel cut from happening at 15psi if my vaf is being maxxed out?
To a point, yes. Someone recently just did this, even running an n/a ECU i believe, and put down like 300hp? I'll try to find the thread.
Originally posted by bomdoutscort View Postthe dudes in florida do it all the time. they run the na ecu and a wideband and just make sure its rich under boost. its good for speed but bad for gas mileage
Those guys should still be able to see 25mpg combined or so if they dont drive like morons.
My MX6 probably dips into the 9s under boost. I still get 25-26mpg combined.
Originally posted by concealer404 View PostWell, in most cars, when you're in boost, it's bad for gas mileage.
"Who Dey"
Well it finally quit snowing so I went out to the garage and switched my stock vaf to the code b vaf and took it for a spin it's holdin 11 psi with no cut out wideband reads 14.7 at idle and 12.5 at full boost. I was seeing 10.0 at full boost with the stock vaf and it would cut out at 4 to 4500 rpms so far so good I guess...I need to fix my p/s rack bushings now cause there fallin out and when it spools you can't hold it in the road and I know torque steer can't be that bad on 11psi on a vj20 lol so hopefilly I can put my new bushings in and be good to go.Just wanted to let you guys know so far the code b vaf has fixed mine.Not sure if it's had the spring adjusted cause it has been opened before I got it hope this helps.
1994 Escort GT Turbo
Like i said i'll let you know when i get my new vaf. I'm gonna switch out the vaf to see if it fixes it. then i have a Electriconic boost controller which i wont be receiving till sometime next month i bet but atleast its being shipped. Then i have my exhaust side flange that i'll be getting soon also. Then i'm gonna divorce the wastegate on my turbo and run an external wastegate.Cincinnati, ohio Bengals for life
"Who Dey"
