ok, well ive been drivin the car around for a while tryin to get the feel of everything and tryin to let everything settle in before i go pushin it to the limits..lol But, for sum reason, im hittin fuel-cut with less than half throttle and at like 7psi boost. the wideband is showing 10.0 and hittin fuelcut when i try to WOT, normal driving is jumpin around at 13.9-15.8 all the time, and idle is at 14.3-14.7. I've tried tuning the vaf, and everytime i go to WOT, or even half throttle i hit fuel-cut. its like if i hit more than 7psi, its cutting back on me. Its been doing this the whole time ive been driving it with turbo. im just curious as to whats goin on. im goin to check the timing 2mrrw. and i also still need to change my oil and spark plugs. just tryin to get the kinks worked out before i do. If anyone has any idea, plz lemme kno.
Setup:
t25/t28 turbo
460cc injectors
rx7 vaf
gtx ecu
gtx intake mani
walboro 255 lph FP
AEM wideband
4 wire TPS
Drew
Setup:
t25/t28 turbo
460cc injectors
rx7 vaf
gtx ecu
gtx intake mani
walboro 255 lph FP
AEM wideband
4 wire TPS
Drew
