+1 chill the fk out man
95 MX3 with BP1.8 non-turbo megasquirt? need some info
psiiturbo i dont want to turn this into a net war. All i wanted to know is what the ecu codes were for the BP motor as I am not familier with them. Im being as nice as i can with out loosing my patience of you not being able to read carefully. I am not familier with BP codes. Maybe if your soo clever you could help instead of bashing and should read more CAREFULLY.
SO i found the code its running off the 1.6.
Are you possative its a 1.8? The 1.6 out of the mx3 looks about the same. Look on the distributor side of the head and grab thise numbers. That will tell if its a bp or b61993 Protege LX-Midnight's shadow SOLD
to get it to run 100% you would, but you could get it running on the 1.6 computer and harness. which it sounds like that's what he did.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
mmmm probably? you will have to make sure that it will plug and play in the mx3. sometimes a few wires will need to be changed here and there for the plugs that connect under the dash. i wouldnt know exactly as i dont own an mx3Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Well, I did the swap from 1.6 SOHC to 1.8 DOHC there were just one cable I had to add, Its been a while since the swap on the 323.
The only cable added was the one for the disty, besides that I think the other one was some solenoid but after some reading it was not really needed. My Mazda 323 was from CA so some of the wire color code was not the typical diagram legend one finds on a autoshop manual. Some common sense when soldering had to be done to make it work.
One of the reasons I am holding back on my MS migration is I want to get the complete 1.8 dohc wiring cables from any junkyard. All I am waiting is for some hands on momentum to spend a few hours under the sun to take it out, LOL.
Good Luck!
