after driving the car for about 1500km i still have some little problem but the car drive good. i was at the solo today and i started to have a vacuum leak. its between the intake and ms2. anyone tried to run the map inside the engine bay??? i was thinking building a box to fit the ms2 map in there and running wire to ms2.
ms2 with exterior map
just use a better hose. i run some hard plastic tubing within my wiring harness bundle, with a few inches of soft rubber hose at each end to connect it. works great...Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
