First of all I am trying to run ms1 version 3 on a escort that was a gtx ecu. I have all the wires hooked up except for two. The gtx pinouts are what I have been using for the wiring diagrams. I am having a problem figuring out where the distributor signals go on the megasquirt. The gtx pinout says Distributor (NE-signal) and the other says Distributor (G-signal). What are the NE-signal and G-signal? Does it go to the tach/crank position output?
I have no idea what code it is running. Does anyone have a link for the lastest high resolution code?
Also I have had no luck getting it to communicate with my computer. I am using a swine usb to serial adapter. It is set to 9600. Would not having the ne-signal and g-signal hooked up cause me not to be able to communicate. Do I need to flash the megasquirt in order for it to communicate? I am sure the wiring that is hooked up is right. Tested for power and ground and both are fine. Anyone got any suggestions? below are some pictures I have been using to wire it
