the table sizes are diff and there are diff. between ms1 and 2 so im sure 3 is diff as well... what exactly are you looking for? spark/fuel tables?
josh helped me out with mine a while back he may have something a little closer to what you need then what i do.. I dont mind sending you a copy of my MSQ you can give it a shot but idk if it will transfer over correctly and all when you load it into TS..
give me your email and ill send you a copy of the MSQ im currently using its a bit rich over the whole map and the spark tables are hardly touched but she runs fine and is a good starting point..
im sending my msq my spark and fuel tables to ya now.. not sure if they will be compatible at alll so i take no responsibility if u fuk something up lol my **** runs fine like this but its with MS1..
