This could be a dumb question....
The disc in my BP dist. for the hall effect sensor has 4 cut outs and a 5th longer cut out in between and above 2.
Is that longer 5th cut the home trigger?
Do I need a 4 wire distributer plug to use it? The BP is in my sohc car so I'm not sure my 3 wire is the right one.
Thanks for info and sorry if its been coverd, couldnt find anything with my searchs
