is the bp26 fuel rail different from the N/A bp fuel rail? if so what are the differences?
bp26 fuel rail
Originally posted by theredrocket View PostThe BP26 fpr is 38psi, and the N/A fpr is 43.5psi... I thought the lines were different also. The BP26 rail has the feed and return hard lines on the same side of the rail, whereas the N/A rail has the feed and return hard lines on opposite ends of the rail.
the Ford BP fuel rail has the inlet on the same side and the return on the pass side of the manifold with the reg. turned 90degrees..
the Ford BP reg is the same pressure as the Mazda BP reg. but the connection is diff. due to fords plastic lines vs mazdas rubber hose. you can still use the ford FPR on the Mazda rail u just have to cut the fatter end of the reg. off for the standard 5/16ths fuel line to fit the reg. and then the hard return line mounted on the Mazda rail
Originally posted by EGTeric93 View PostMazda BP fuel rail and GTX rail are identical aside from the FPR.. they are mounted the same but the pressure is diff..
the Ford BP reg is the same pressure as the Mazda BP reg. but the connection is diff. due to fords plastic lines vs mazdas rubber hose. you can still use the ford FPR on the Mazda rail u just have to cut the fatter end of the reg. off for the standard 5/16ths fuel line to fit the reg. and then the hard return line mounted on the Mazda railTyler has spoken
