Wideband for MS
    Wideband for MS
    I've been looking at 14point7's SLC PP2 for a while now because I like their rectangular display and price. However, I can't seem to find any usage reviews for it. The reviews I have found are mostly about assembly. Does anyone here have experience with it? I'm really asking about accuracy and resolution here.
    I'd like to go ahead and get a wideband soon (now), and then get a megasquirt in a few months if I still can (likely). So I'd like to know if this is a good product in general, and also how well it works with MS.
    1990 Protege 4WD
    1 3 5
    2 4 R
    ive seen a few of them working with MS so I know its possible but I have no hands on experience with them.
      Well that's encouraging.
      1990 Protege 4WD
      1 3 5
      2 4 R
        I'm going to buy it on monday. If anyone knows of any reason why I shouldn't, please share it before then. Otherwise I'll look forward to finally having a wideband to tune.
        1990 Protege 4WD
        1 3 5
        2 4 R
          Ordered. Will update as I go.
          1990 Protege 4WD
          1 3 5
          2 4 R
            Which WB did you order? I've scrolled through there as well, but I was unclear which were just gauges, and what were full WB units lol
              SLC PP2. The controller is in the box with the display. It's supposed to do datalogging and stuff too.
              1990 Protege 4WD
              1 3 5
              2 4 R
