Originally posted by Mazda_Powered
View Post
Innovate MTX-L Install
Well i cant do anything about adjusting mixture now as my sensor is playing silly buggers. Went out dfor drive this morning and all was good for a while, then i started getting silly readings, one minute its 8, the next its 22, and now its just stuck on heating up when i turn ignition on, and also seen code E8 pop up. Tried recalibration and just get the same crap. Im pretty pissed off here as after reading about it it seems its a dodgy cable/connectors. Ive looked at them, unplugged them, checked all wires, re-ground to engine to no avail. Wish i had gone with an aem now.
Getting error "No serial port, IMS USB device, or IMS Network device detected"
What driver did you use?
Lack of autorun ftl.
Originally posted by AmmoJammo View Post1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
Originally posted by MazdaNoob View PostMy sensor **** the bed as well. Bosch 17014 FYI is the replacement
Sent from my iPhone5
using Tapatalk
My problem is I bought a Chinese ebay converter/adapter and the driver disk I got for it is nondescript. I don't know wtf. I sent the seller a request for help so we'll see.
Why can't people properly describe their ****? It's irritating.Last edited by 1st Gen; 06-08-2013, 06:54 PM.1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
This was unexpected.
"Sorry for the trouble.
We know that it’s not honest to send defective items to customers. So our manufacturers do test all of our products strictly before sending them out. But such electric products may get damaged in the post easily.
Our system doesn't support resending now. In this case, how about we fully refund you and surely you don’t need to send it back to us as the postage costs much? Is it ok for you?
Looking forward to your reply.
Sincerely,
Victor"
I'll fart around with it more later. I should be able to test just to see if it works at all.1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
