Here is my car: 1995 Ford Escort GT
1.8L-T GTX engine (NGK BKR7E plugs)
VJ-20 turbo
BP26 ecu
RX7 vaf
330cc(stock gtx) injectors
BP fuel rail w/ stock fpr
255lph walbro fuel pump
4 wire TPS
FMIC 2.5" plumbing
turbo smart dual port bov
turbo smart boost tee MBC (set to 13psi)
innovate LC1 wideband (needs calibration badly)
I have had my swap running for years and I daily drive it at 8-(10psi creeps) without a MBC on it. In the old days I wanted to run higher boost so I had a hallman pro mbc and set it to 15psi. I would get a weird full boost event back then and it appears I am still getting it now that I just installed a turbo smart boost tee mbc. Back in the day the wideband was working fine and afr's were prime under full boost, 10.5-11.5:1, idle was between 14 and 15.5:1, and cruise was 14.5-15:1. I removed the mbc the first time around because of the event and how it scared me...I didn't want to blow up my swap. Now I have an itch and I want to know exactly what is going on.
Here's the event:
Cruising up a hill, in 5th, usually under 50mph, floor the gas, boost builds to 15(in the old days), at some point under all this load the engine felt as if it hit a tree repeatedly and I swear it had blown up. I let off the gas a push the clutch in...engine idles fine.
However, lets say, 1st gear roll. I punch it..spools up violently fast and spins tires and roars up the street without event...
AND, in second at a roll. I punch it above a certain rpm...say 2000rpm, and it screams down the road at 15 psi without event..
Now, back then, if I were to punch it under 2,000rpm and the boost reaches 15psi in now time the event happens at low speeds in second gear, third gear, fourth, and fifth. It seemed as if all I had to do was cruise past 2,000 rpm in lower gears and all was well until 5th gear. It implied that too much load on the engine was the cause of the event.
With all that said, I have been creeping up on 15 psi all this week one click at a time. I'm at 13psi now. I haven't had the event happen until this morning. It barely happened but I distinctly remember what it felt like. This was in 5th gear up a hill and it spooled to 13psi and the engine felt like it shut off for a spilt second but sort of violently. I knew what it felt like so I tried again. No event. Again and again this morning I tried to reproduce the event and nothing happened. I'm very confused as to what this is. Until I recalibrate my LC-1 I won't know the current afr's.
So back to my original subject. Does anyone KNOW what boost cut/fuel cut feels like and what predetonation feels like?
- Cole
VJ-20 turbo
BP26 ecu
RX7 vaf
4 wire TPS
FMIC 2.5" plumbing
Here's the event:
- Cole
