So I've been assembling my ms2 v3.0 board and I'm at the end of it and had a couple questions for anyone who has done one..
Basics :
1988 323 GT, swapping a BP-T, retaining the stock single coil and 4/1 distributor. Using the stock 2 wire pwm idle valve.
Questions
Based on the install directions , do I use the BIP373 in the Q16 slot, and then mount the TIP122 on the ground bar and attach my pwm jumpers? Or do I not use the BIP373?
And for the 4/1 dizzy , there are 2? Possibilities based on what im reading on assembly the 2G 4G63 , or the mitssubishi cas 4/1 , the picture they show and mine look like the 4g63? So do I follow the 5.2.14.2 to add cam sensor input? And add the pull up resistor in my proto area?
Don't know if im just over thinking this or just confused for no reason. But any input is appreciated !
Basics :
Questions
