o.k i swaped a GTX into my 91 Escort GT useing the GTX harness/ecu and the motor , then i had to splice some wires from the gtx harness to my interior harness i spliced them all the right way, but for some reason my fuel pump won't turn on.
so i went and hardwired my fuel pump directly to my battery using a fuse and a relay and the pump turned on then i ran the gtx for a while.
i went and checked to see if i had power on the gtx side of the harnees before the splice to my stock Escort GT interior harness and had nothing a GREEN/RED wire.
So by hard wiring my fuel pump will the gtx run right, or does it need a certain signal at a certain time to run right.
thanks ryan
thanks ryan
