Alright someone clarify me on this one...
The ecu controls the injectors using the airflow amount.
When car is boosting, the sensor registers higher airflow at lower rpm (say the amount of air going through at 5000rpm na is now going through at 3000rpm at boost).
So, as long as the ecu has a map for that amount of flow, it will adjust injectors correctly.
At some point, amount of airflow will jump off the ecu map, and the computer will open it for the amount of time registered for the last max flow causing a leaning condition.
Correct?
Right now i'm running 460cc and SAFC tuned for -45% across the board on an n/a car. When the turbo goes on, the ecu will be still getting a registered flow amount untill about a little less then twice the amount of stock airflow. Will there be a need for additional tuning to make car run safely, or just for precision?
Correct?
