have you actually started this project, or are you still planing, and sourcing parts.?
Feedback for my custom AFC project
.....HELLO MY NAME IS BEN...
186.08whp
225.94wtq
torque monster!!!!
dyno graph 8-10-and 12psi
blahblahblahblahblahblah
status on the project so far:
gathering parts: mostly completed. we are still looking for an efficient way to do A to D and D to A conversion, so haven't bought the converters yet. We have the dsiplay, microcontroller, as well as software to program it. We do not have a PCB or a layout yet. Initially everything will be built on breadboards and tested that way.
We are still doing research on the memory requirements of the unit.
programming: we havent gotten into this too deeply yet, we have a skeleton menu system as well as code for button pressing.
timeline: like I said, by the end of february, hoping to have an "almost working" prototype.
Just as a quick update on how the AFC is coming along:
We have the hardware we need and we have been able to display to the screen and use the buttons to navigate around.
This weekend, we are hoping to have a menu structure working.
We are also scoping out the sensors (sensor ranges) for O2, TPS, RPM, and air flow sensor so we can start on the design of the circuitry that changes the air flow sensor output.
This project is a lot more involved than it seems. A lot of considerations have to be made such as the speed of the system, resolution, and how to deal with extreme cases (such as bliping the throttle). However, considering all these things is part of doing this project from an engineering standpoint, and not from a kid in his basement standpoint. So, in the end, the product will be a lot more safe and reliable.
Sometime in March, we are planning to take her to a dyno and see how well our AFC can tune a car. Hopfully you guys will be impressed and will like to buy some of these units I will keep you posted on further progress
Update on the AFC
The prototype should be done by the end of this month and it should be installed for in-car testing. Our functional spec document is done - which tells you what the exact features of the unit is.
If I could attach a pdf to here, I would post the document up.
I will continue to keep you guys posted.
w00t91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
pm Marc93lx and ask him if he can host it....marc is a badass...91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Here you go guys, I found a place to host it, so here is the functional spec for our AFC. We made a company called ACS, and it's 3 of us that are working on it. Have a look - it's quite technical but if you go through it, it will tell you exactly what it will do.
Ask me any questions if you have any
Enjoy
i remember playing with breadboards back in my electronics classes in highschool...but nothing like that....very nice!91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Here are more pictures of the work-in-progress AFC. In the first picture you can see the calibration menu, where you set your % increases for the particular RPM (on the top line)
The second picture shows one of our car monitoring menus, and the next screen shown is the monitoring menu where it shows pre and post calibration airflow values.
Sorry I haven't been around for a while, but I've kept way too busy. As always, I will keep you guys posted
