What are good EGT Temps? I don't have a wideband and the closest dyno is 3 hrs over a MTN pass so I want to tune my car as good as I can. Also this is for the Probe being right behind the Turbo.
EGT Temps?
Originally posted by elscotto80Mine is about 6 inches from the DP, maybe a bit more. When cruising in 5th it varies from 900-1200, at idle it can go as low as 400, but as high as 600. When I get on it through 3 gears, it gets as high as 1250 or <.
Originally posted by elscotto80Odd, I have the GTX injectors and GTX ecu.
on hte other hand, my car ran 1200F when beaten on N/A. If you are getting those temps in the dp after the turbo, maybe you should get on a dyno to check a/f ratios.... not doubting the ecu or anything, but remember people saying temps in dp are about 300F less then manifold. Which means you have 1500F after the engine :-/ a bit high
Originally posted by Kreatoryou are.... but with cast iron or stainless steel its somewhat inconvenient when you dont have proper tools. So it's much easier to tap the downpipe.
Originally posted by Kreatorhmmm.... mine sits 2-3 inches down from the turbo and i can barely push it into the 800F zone :-/ guess ima running r$$$ch!
Originally posted by Kreatoryou are.... but with cast iron or stainless steel its somewhat inconvenient when you dont have proper tools. So it's much easier to tap the downpipe.sigpic
92 240SX: KA/T25, nerd mobile
Originally posted by atomicEGTproper tools being something other than several drill bits, a pipe thread tap, and motor oil?
ss manifolds have collector, but they are too thin to tap and require a bung - which is hard to weld if you don't have a decent welder. you could obviously take it to shop, but i dunnow... i felt lazy and didn't want to **** up the manifold.
