As the title asks, does anybody know if there is a difference between the 1.8 GTX and GTR throttle bodies?
Is there a difference between GTX and GTR throttle bodies?
Last edited by ftjandra; 06-26-2005, 11:44 AM.If you can't differentiate between brake and break, you should go back to school
Factory Service Manuals and Familia Brochures - PDFTags: None
Originally posted by atilano the throttle are the sameIf you can't differentiate between brake and break, you should go back to school
it's even the same has a bp automatic. The only difference with a n/a manual bp is the shaft for the tpshttp://www.cardomain.com/id/protila
Transmission mechanic
Thanks for confirming that they are indeed the same, Atila and Popsicle.If you can't differentiate between brake and break, you should go back to school
