On my truck (Ford F150, 5.4L Vortech Supercharged/intercooled) I been recently having a lot of issues with my spark plugs. I changed the factory Ford Motorsport Platinums at 62,000mi the other day. I replaced them with Bosch double tip plats. They sucked, truck ran like ****, barely idled, died at a couple stoplights, plugs fouled within a week. I replaced those with bosch single tip plats. I figured the double tips sucked because the gapping was incorrect, and you cannot alter those particuliar plugs. I gapped the single tips I am currently using to the SVT Lightning gap specification @ .058. So immediately after installing the plugs my truck felt great, instant response, immense power, couldn't get the tires to stick through 1st, 2nd, and part of 3rd. Now my truck is beginning to idle a little poorly again, not like it did with the other double tips, but not perfect nonetheless. The power is not there like it was either. I think my plugs are fouling again. I don't understand this, is the gap too big, or too small. Someone suggested that plats are no good for supercharged applications, and I should use iridium plugs. I never touched any of the other stuff, and she ran fine before, just not as much power. Oh and I just got my V1 rebuilt about 800miles ago.
Any suggestions?
One other question, the truck runs a granatelli MAS, and all the vortech FMU crap, with factory injectors. I ran 6psi for a while and just recently bumped it to 10psi. Should I install bigger injectors, or will there be minimal/no improvement?
I know this is unrelated to pro's but I really need help on this and most people I have asked haven't been much help. Vortech told me I shouldn't alter anything. They said if I change anything, I.E. the pulley, and the larger bypass valve they can't help me because they don't deem it "safe."
Thanks in advance
Any suggestions?
Thanks in advance
