Id say go with the turbo, you won't want to turbo that FSZE. The compression is a little to high to run safe boost unless you use a stand alone or a really good piggyback to control timing and fuel. Also note that the FSZE will not yeild 170hp, wont even come close. It is rated at close to 160 or so, its just in a different measurement. then factor in drivetrain losses and the fact that the ECU is different and you might see 120whp at best. Now when looking at turbo kits you might also consider the size of teh turbo, 10 psi on one is different than 10psi on another. I believe that esential speed uses the smaller turbo to get boost earlier. Thus they can go to a much higher psi and make similar numbers but have better driveability. With the essentialspeed kit at 10psi you would be looking at around 200whp. Their kit is well manufactured as I have had mine for over 40K and no problems yet. Any questions feel free to ask
Which turbo kit should I get?
cool...whats the max boost u guys can run on ur engines? bp-de's can run about 20+ stock...how high can u go?Last edited by silver03p5; 10-27-2003, 03:43 PM.sponsored by www.protegegarage.com
yeah, thats straight...i heard that rods are thrown over 15 psi thosponsored by www.protegegarage.com
so what's the best turbo to get for a 2L pro?
and just to make sure there's a nice concesus on this... turboing an FS_ZE isn't possible/advisable? I was looking into getting one for my car, then adding a turbo to that?
I have looked at the HiBoost turbo... seems pretty solid and esthetically pleasing.. and it's an excuse for me to drive to FL for a week
Kenwood KDC-519 w/ RF 500bd + e12K.44
RB springs
Magnaflow catback
2004 mods:
MP3 front bumper conversion
ok...
well.. it's not like i could afford this for another year, anyways.. i have tons of outstanding debts.. so i have lots of time to sit back and see what designers come up with... probably in like 18 months or so, i'll have enough cash to get a turbo.
i'm never going to just drag my car.. i may go a few times to the 1/4mile track we have.. but that'd be it..
just hard city driving...
RB springs
Magnaflow catback
2004 mods:
Ok, first the FS-ZE will not make 170 hp...170 ps is the power rating.
Second, the 170 ps is on an OBDI set up. You would have to do some serious work to make an OBDII car switch to OBDI runnign style. Can we say wiring nightmare. Not to mention really illegal!
And, you can turbo an FS-ZE, but what's the point? The compression is high and that limits your boost big time.
As far as the best turbo, it is your decision. But, I'll vouch for Flyin' Protege on their stuff. It's good and runs great. Plus they have plans for big advancements over the winter months. Stay tuned turbo fans..."Hey look at me, I'm stupid as hell and can't even breath properly, little alone read!" - Master Shake
2001 Mazda Protege MP3, with Flyin' Protege Turbo Kit
www.triplezoom.com
ok, i have some things to add/say as well... if ur lookin at spendin the kind of $$ ur talkin bout for a KIT ($3-5k, right?), then y not learn a bit more and BUILD a kit... ive got my entire kit planned out, and itll come in slightly UNDER $1000, and be upgradeable (which any turbo 'kit' is actually) in the future when i get more $$ for better internals i KNOW will handle the pressure, as well as a standalone (tec 3 prolly at this point..)
first - buy a used turbo if possible... check shaft play, talk to ppl around the guy ur buyin it from (im talkin bout buyin local, like im doin..) and see how it was run, how it was hooked up, etc... im buyin a used 14b, fully ported for $50, cuz its blown... send it out to cheapturbo.com, and $250 later BAM!! theres a brand new turbo... im gettin a FREE fmic, i just need to pay a local shop to hack the end tanks off and re-tig new ones on for me... my full exhaust and ic piping will all be made from mandrel bends i buy from burnsstainless.com... just have everything welded together by a shop that knows what theyre doin... used dsm injectors... a good afc (apexi is really big around here...) the turbo manifold is actually going to be my stock exhaust manifold, with an adapter milled and welded onto it to mount the turbo... drill a hole in the oilpan and run an oil line for the turbo, throw on an mbc, and ur set!!"Squirrels are evil because they have thumbs."
- Chick McGee
see, u can do that with a 1g, cuz its bettar...with a 3rd gen u must worry about explosions and whatnotsponsored by www.protegegarage.com
