Ok, I'm doing some research on camshafts... I'm gonna grind my BP camshafts, but I'm not sure what's good lift and duration without going over where I have to change the solid lifters to locked lash ajusters or inner shims. I have stiffer springs which have a 12mm max lift.
Here's what I've found...
Stock... Specs
Intake: .319" lift and 196 duration @ .050"
Exhaust: .338" lift and 202 duration @ .050"
Corksport... Specs
Intake and Exhaust: .352" lift and 205 duration @ .050"
Toda... Specs
Intake and Exhaust: .354" lift and 256/264/272/288/304 duration @ .050"
I was thinking .354" lift and 264 duration @ .050" would be good for street use. I'll be running my built up BP and turbo...
Anyone think otherwise?
Stock... Specs
Corksport... Specs
Toda... Specs
