ok so im in a tough spot.
i got my motor in and started up thanks to sonicdelema. but im only running on 2 cylinders. i have...
-run stock injectors
-run stock ecu
-got compression of 150 in all cylinders
-tested spark and i am getting spark in the 2 cylinders
now my problem is its the 2-3 cylinders not firing. which as sonicdelema explained to me the ecus being batch fire 1-3 4-2 it didnt make sense to him that 2 cylinders not firing, getting compression, were not even in the same batch.
im going to try to pull codes... but first its time to put some food in my stomach.
-run stock ecu
