Hi! I would like to know if it has differences between bp crank of standard 1.8 DOHC, the GTX or the GTR. Thanks!
crank bp-bpt gtx/gtr
afaik the standard BP and gtx have the same crank. the gtr crank is lighter (and stronger) i believe. not sure of the exact differences. i bet ryan will chime in on this one
GTR crank-27.8lbs made of kalmet compitition grade steel---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Thats incorrect. Yes the GTR has a large crank snout & yes it uses multi-rib pulley instead of the vbelt. thats the only exterior differences---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
so dimensionally its the same as any big nose crank?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
