well i had the engine running most of the summer. and i installed a comptec FPR and some 460's. well then someone told me i had my adjustabe gears tuned wrong for the big ass cams i have. well ever since the car wont run worth ****. it idles just fine, and drives like crap no power it just spits and sputters untill you hit 5K and it takes off like a bat out of hell, i tried every thing. it acts like it has a plugged cat but its 3" straight threw.
i went back to TDC and went fron there. the cams should be diled in perfect where they sit. well i started to get some blue smoke, im thinking its from the turbo as there is some slight residue in the IC piping, and the more it spools the more it spits out. and i have no blow by.
i was thinkin it might be a valve, so did a comp check. cyl. 1-175, 2- 165, 3-170, and 4- 170. they arnt that far off from each other, so that kinda rules out a valve.
im thinking maybe a leak in the turbo man, or the VAF out of adjustment. the oil is clean, no metal flakes nothing. any thoughts on this guys. maybe the turbo is screwed. i am just not sure what the heck is going on. any thought would really help.
and a short list of stuff in the motor
8.4:1 com pistons
1mm over ss valves, evs springs
spec E cams 286 duration 11.38mm lift
IHI VF12
GTR intake mani
8.4:1 com pistons
IHI VF12
GTR intake mani
