I've been tryin to figure out a gremlin that has plagued my car for about a month now. The main problem is that for some reason, my base timing is messed up. If I set it at 12 deg advance, its not right, its WAAAY retarded. I have found that it runs right at 32 degs advance. It runs right at idle and at cruise, but when it starts to boost, it starts to pull like crazy then falls on its face, boost gauge drops to zero and wideband pegs to rich. It seems as though the computer is cutting spark. Some help with this would be great, i'm at my witts end.
My setup:
BP05
P&P Head
Stainless Valves
.50-.63, 57 trim Master Power T3/T4
1 3/4" ramhorn
Mark 2 Deltagate
Turbonetics MBC set at 15
3" mandrel downpipe
3" mandrel exhaust
24x11x3 Greddy Intercooler
2.5" mandrel charge pipes
Greddy RS BOV
GTX ECU
GTX Injectors
GTX Intake Manny
AEM WideBand
AEM Water/Meth Injection
Things i've tried to fix it.
new engine temp sensor
swapped tps
swapped air meter (gt)
new plugs, wires, cap and rotor
plugs gapped .028
swapped distributor
belt timing is right on
No vac leaks
No charge pipe leaks
fuel pressure is good
I've searched on here and found that there are a couple people who have had the same timing problem but nobody has posted what the fix was. Thanks in advance for any suggesstions.
My setup:
BP05
P&P Head
Stainless Valves
1 3/4" ramhorn
Mark 2 Deltagate
3" mandrel downpipe
3" mandrel exhaust
Greddy RS BOV
GTX ECU
GTX Injectors
GTX Intake Manny
AEM WideBand
swapped tps
plugs gapped .028
swapped distributor
No vac leaks
