Just purchased an Audi 5000 external wastegate to use with my 16G setup I'm working on. The valve is 30mm so I'm wondering if it will be enough. It will be used past the turbo with the turbo internal gate removed and hole enlarged.
Here are pics of the wastegate
Also, what is the purpose of the outer ring around the valve itself?
