vj20 on a n/a bp with a gtx/r ecu. is there a way to keep it permanently open without taking apart the intake manifold? or is the best way to just open it up and rip out the butterfly valves?
best way to keep vics open
its the vac line that goes to the VIC solonoid lol. not the pinkish sensor.
JACK.-Jack
believe it or not, but you want this to function just the same boosted as you do NA. Mazda really did have purpose in designing it the way they did, you can see 15+ ft lbs in the low range having the VICS functioning properly.
i reccomend 4700-4800 for an opening point under boost. if you can figure out how to do this. Mad props. just share it with the rest of us.
Or just plug the vacuum directly to the intake manifold.They will be closed at idle and be tottaly open from atmospheric pressure and above...
Their normal position is open. Only vacuum is used to keep them closed...---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
