Has anybody encountered this problem? The bracket that should go on the starter for the GTX (or GTR) motor is different. My motor didn't come with the bracket. The thing that's different is the intake manifold. It doesn't bolt onto it the same way. Has anybody encountered this problem and have they figured a solution? Thanks
GTX starter bracket different?
You don't need to use the bracket, it just bolts to the intake manifold and isn't necessary.. I have a set of DOHC LX starter, alternator, and fuse box all assembled with the harness if you want.-Braden
'05 WRX
GTX Groupbuy is Closed! However you can still pick up a GTX motor for only $925!!! PM me for order details!
