ok so i figured id ask this on cp instead of mx6 or probeperformance, i officially bought me a 1g pgt with some aftermarket / custom parts on it. The car has a blown "t24" turbo on it which is remotely mounted by the transmission. I can't find any information on the turbo and im not a turbo guru or anything so i really dont know what to look for as far are replacements. Id like something that can bolt onto the setup of the car the way it is so i dont have to do any cutting and welding, but if i have to ill just get someone to do it for me. I have also heard from people that the t25 and the t28 sometimes share the same flange with the 't24' turbo. It is a garret and i took plenty of pictures of it so if you guys can help me identify it and point me in a good direction as far as replacement id appreciate it. remember its a 2.2 sohc turbo, jet chipped ecu, full turbo back 2.5' exhaust. custom grind cam shaft from some guy in canada, custom order low comp weisco pistons. The guy told me he used to run 12's in the 1/4 mile with this setup. he apparently got kicked off the track for running 12.34 and not having a roll cage. Thanks!
need a replacement for this turbo
Tags: None
Originally posted by deathtrigga View PostThe guy told me he used to run 12's in the 1/4 mile with this setup. he apparently got kicked off the track for running 12.34 and not having a roll cage.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Postthe guy was a bull****ter, you don't need a cage until you run 11.49 or faster.
no cage needed in the 12's"Discontent is the first necessity of progress."
Originally posted by deathtrigga View Postok well whatever lol he said he got kicked off the track for something mayb it wasnt roll cage i forgot what he said but he said it did 12.34. anyway can someone help me out as far as a replacement turbo. Also bombdout where can i compare my gasket online?
Originally posted by Loco_R View PostGuys like that the comunity should castrate him for sparcing the ignorance in the world. That could hurt a lot of generations to come with the gene of ignorance.~PaTricK~
-Current car's-
~ 92 Probe GT Turbo, 90 FE3 Turbo 626GT hatch, 97 KL mtx 626, 05 Mazda6, 09 Kia Sportage V6~
What are you driving?
