So first off I'm running a bp26 ecu, y code vaf, and F2T injectors, stock fuel pump, vj20, ungraded FMIC, turbosmart BOV (VTA), and a CS downpipe.
At idle I'm usually around 14-15, crusing it varies a lot, but when I go into boost I lean out and go high 13's to high 14's. Naturally I let off because I'm lean so Idk if it gets worse than that. The stock VAF hadn't been touched before I got it, I was told to turn it 2 clicks CCW and it didn't help the issue either. also, if I ease into boost it doesn't cut at all, but if I mat it to the floor I get fuel cut (i think? its just a really hard cut, idk how to describe it)
My timing is at 14* too.
I'm going nuts figuring this out.
