Just wanted to let you guys know that I am working with delta cam to do some magic on the BP26 cams.
My idea for the grind is to keep the original characteristics of the BP26 cams; just increase the lift. By how much, i'm not sure. Delta wanted to wait till he recieved the cams before we talked about the grind. Input on this would be appreciated.
For those that don't know, this type of grinding lowers the radius of the base circle in order to achieve higher lift and duration. Because of this, you would no longer be able to use HLA's. A conversion to solid lifters is necessary.
This will be an always available grind. No group buy or anything necassary.
BP05 regrinds will come later.
Also, if someone has a set of BP26 cams lying around that they would want to offer up, that would make this process quicker. I'm working on buying a set but I'd like to get before and after dyno numbers. I'm going to the dyno on june 18th and I think its possible to get this done by then.
