Hello i have a few questions that i know somone in here can help me with. I have the mazda BP-t gtx swap in my escort gt, I have been using it as a daill driver for almost 2 years. Recently my turbo finally gave out.
I need a rebuild kit or a new turbo all together, the old vj-20 can be rebuilt without problems but id rather just a whole new one, I was told for the rebuild kit and IHI RH5b will work is this true.? does that go the same for a new turbo/ ive been looking online and came across this turbo on ebay.....
can somone onfirm wheather or not this is the same turbo? i need some help, the gasket and everything appears to look the same but it says its for an isuzu or somthing.
if that is not the right one could somone point me in the right direction, also is there any other turbo that will bolt right up perfetly with no extra modifications/
i also had another question about my blow off valve, it is currently blowing off into the atmosphere which makes it stall somtimes because all of the measured air is leaving and not going into the motor, i was told that it was better to re-direct the blow off air back into my intake after the maf sensor or somthing, is this a good idea?
thank you in advance for the help everyone
