Originally posted by Ace
View Post
VF10 @ 15 psi Dyno!
Good numbers!!
now im wondering what my vf10/vj20 would have made at 12lbs on gtx motor with cs downpipe and 2.5" exhaust,fmic.... was limited at 12lbs with gtx ecu y code and 360's it would cut any higher. i was thinking right around 200 whp...Last edited by Chad; 11-09-2012, 02:28 PM.
Was this on gas? On e85 and 22psi on that turbo i made 300hp and 330tq on a mustang dyno. Going to the dyno tomorrow with my new car and gunna see what it will make vj-20 on 16psi. Should be north of 250 baised on cars it beats. Its a 100% stock protege longblock with the stock turbo parts bolted on 460cc injectors and e-85. Front mount,intake and exhaust.sigpic
1993 Mazda Mx-3 RS Black 300hp 330tq Mustang dyno, vf-10/vj-20 hybrid 26psi, Megasquirt Tuned on e85
1/8 mile 8.50@89 2.3 60' Parted out and missed!
1993 Mazda Mx-3 RS Blue Bp turboed VJ-20 16psi, Custom vj-20 inlet pipe, Custom 2.5 front mount intercooler, Custom 2.5 downpipe to 3inch outlet side exit exhaust, Rx-7 460cc injectors, Tuned on E-85 with Ems Pro, Corksport front / Rear strut tower brace and H&R lowering springs.
1\8 mile 8.81@82.66 still at 2.1 60'. Parted out
2004 Volkswagon Jetta Gli 1.8t Eurojet fmic,3inch downpipe to 2.5 cat back,apr stage 2 software, cold air intake and turbo inlet pipe and St coilovers slammed to the ground.
Sold and missed!
2012 Volkswagon Jetta S 2.0 8v Custom Cold Air intake, Raceland Coilovers, BFI Torque Mount Insert, Audi S4 Wheels, low and slow.
Daily driver
Originally posted by BlackMazdaMx-3 View PostWas this on gas? On e85 and 22psi on that turbo i made 300hp and 330tq on a mustang dyno. Going to the dyno tomorrow with my new car and gunna see what it will make vj-20 on 16psi. Should be north of 250 baised on cars it beats. Its a 100% stock protege longblock with the stock turbo parts bolted on 460cc injectors and e-85. Front mount,intake and exhaust.
If you click the link in my signature I got updated numbers on the dyno out of the VF10.
The gtx ecu, b code vaf, 460cc injectors are easy for me to attain, however the VF10 turbo is not that abundant here in Jamaica. My turbo pickings are from the following jdm factory turbo cars.
Mitsubishi tdo4 & tdo5
4G63T
4G93T
Toyota ct20b & ct26
3SGTE
1JZ GTE
2JZ GTE
Nissan t25, t28 & t3
SR20DET
RB20DET
RB25DET
RB26DETT
CA18ET
VG30DETT
Subaru tdo4, tdo5 & VF20 up.
2.0 L EJ20
2.5 L EJ25
I've never seen a VF10 turbo other from what I've seen online so I cannot compare what turbo its equivalent to. Which turbo would you say is equivalent to the VF10 from the list I've given?Last edited by mazkam; 10-12-2013, 03:37 PM.
