Oh wow I just lined up to order manifold off of a guy from the site with bunch ofher parts Wonder how good this really would be though and if it's welded proper. Pieces inside the manifold could let go from the weld and kill your turbo
As above. Throw away the included gaskets and hardware, they suck, but the manifold itself is actually quite sturdy. I bought one for my GT28 hybrid and with new hardware and gaskets, works great! The hardware it came with kept backing off, causing the exhaust leak that destroyed the gasket.
I'm using mine as a paper weight and put the OE manifold back on. I did notice the turbo flange is crooked making it tricky to run the hard oil line to the turbo, and runner 4 is noticeably longer than runner 1. The welds actually look pretty good, smooth and doesn't look like they were ground down.
