I just make a BPT swap for my 323. The BPT engine has a 4 wire tps but the old engine has a 3 wire tps. The car is a 5 speed manual. I make the combination to convert 3 wire to 4 wire. The funny thing is when I connect the TPS and I accelerate, the car bogs and stall. I notice the first 2 pins of the 3 wire tps at WOT has full continuity. Same situation when I check the 2 pin with the 3 pin of the 3 wire tps but with the throttle close. With the four wire tps, the 1 a 2 pin have continuity also at WOT, but with resistance. Same situation with the 2 pin and the 4 pin of the 4 wire tps with the throttle close. I try to adjust the 4 wire tps but with no success. I know the resistance is the problem.
I will appreciate if you guys can help me with this.
Thanks
Thanks
