How are the kartboy shifter bushings versus the CORKSPORT Bronzeoil Shifter Bushings? Kartboy only uses 2 bushings while corksport replaces 4.
The Kartboy shifter bushings and the Corksport bronzeoil bushings cannot be compared as they serve two different functions. The two Kartboy polyurethane bushings are designed to replace the single OEM rubber bushing at the end of the extension bar. The four Corksport bushings replace the OEM plastic bushings located at each end of the change control rod-two at the gear shift lever end and two at the transmission end.
The purpose of all the bushings is to reduce play and wasted motion in the gear shift lever and relative motion between the transmission and shift mechanism.
Happy Motoring!
I can't help you out here. I've only used the Corksport bronzeoils so I have no basis for comparison.
Happy Motoring!
