Looks like they do a good job.
Are the bp and rx7 pintle orings the same size?
That's what I was told. A member(I think wheresthericego) told me he sent his in and they put rx7 orings,ect on and he dropped them right in
I'd recommed using Linder: www.lindertech.com
These folks are first rate. Also, for the guys doing this for a living, I recommed thier Guru School, it is worth the money.
i sent my rx7 460cc 195500-2010 to neweraperformance very bad experience should have sent them to another company
they only replaced filters and told me that they didn't have the caps or any of the other stuff in stock this was after the fact that i got them back and called you would think they would call you first before they did the work with out the proper parts instock
when i asked in an email to them why the injectors are flowing over 500cc this is what they said
We use heptane to flow them which is thinner than gasoline, so the flowrates are generally a little bit higher. Heptane does not leave an internal deposit like gasoline does which can seize the pintle after time. That does seem a little bit high though, but that is what they flowed.
flow chart is way off what the injectors are and none of the injectors flow the same
Heptane??!! What's the point in that? Do you really care what your injectors flow on Heptane?
The truth is just about all injector services use the ASNU machine (www.asnu.com) and they use a non-flamable test solution that has the same flow properties as gas. I'm sure your guys are just too cheap to spend the money on the stuff or maybe they are using the flow bench to "clean" the injectors.
Too cheap to buy what? A machine?
I have a turbo kit for sale that i had on my 1996 dohc sephia. Its all custom but not getto rigged. its a hybrid dsm/kia turbo manifold that i had designed at a performance shop here in vegas.
What does that have to do with the subject?
me bitches! my school just bought an asnu machine! I am the first to clean and use some injectors on the brand new machine
Want to clean my gtx injectors on the cheap?
