hi there i never have done a forum before so im sorry if i do something wrong but... i need help really bad. i have a 92 protege dhoc 5 speed and i was going to get fresh transmission fluid, but when i took off my speedometer the gear was missing! only thing i can think of was that the gear broke off and is now sitting in the transmission. i cant get it with a magnet or anything like that. it was driving just fine till i took the speedometer out of the transmission. i saw only one other post like this but it didnt help at all and it was for another car. any ideas??? thanks so much.
speedometer gear broke off in transmission.
Just because it's metal doesn't mean it's magnetic, though. The metal nuts holding my hood scoop on aren't magnetic, for example. I'm not familiar with the layout, but if you can somehow get a light or camera to see in the hole, you might be able to find it and maybe some long tweezers could get it out.
You may have to cozy up to the idea that you're not going to get it out without some major access moves. It should have come out with the assembly.1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
Ya know---if all you were doing was putting fluid in the case, you may be able to just replace the cable assembly and have it re-insert right back into the gear like it was before. No worries. There's also the possibility that the gear is missing all together. Who knows why. You say the speedometer worked before? It's not best case scenario but it's better than some alternatives.
\1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
Did you separate the trans case in the car?Beater=/= Sleeper
i've only EVER seen this happen to the mx3 v6 speedo gears. im quite taken by this.
you will have to live with the plastic chunks in the transmission. and or pull the whole transmission out of the car & tear it down.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
