Need bolt specs for a 95 1.5 protégé alt tensioner bracket. the bolt that mounts to the motor is gone.
help
Hello. I would say try some random bolts from around the engine compartment. When you find one that fits, take it with you somewhere and buy another one just like it.1990 Protege 4WD
