Well Heck........ I am stumped! I recently got a 1999 Mazda Protege, I love the car overall and am happy to have it! In the snow I got stuck and abused the clutch just a little no burning smells or any weird sounds, I got out of the ditch and the next day the clutch felt strange! I continued to drive it and tried adjusting the clutch and it seemed better but totally went out about a week or two later(went to floor and was inoperable!), I bought a clutch kit online and started to do the tear down for new clutch installation and got to the slave cylinder and the piston was sticking out the back of the housing and the housing broke! Of course I thought.......Awesome it's just the slave cylinder....WRONG, got the new slave put it in and same thing it's pushing too far and coming into the boot, I bled and bled and bled, finally using the drip method seemed to do the job.....But still pedal was soft and then very hard near the floor and blew the seal on the new slave! WTF??????? The fork seems to be going so far forward that it has hit the bell housing? My suspicion is the pressure plate is messed up or something came off inside???? Please help, Tony Frazzled in Oregon I guess I'd better get moving on the clutch kit installation? Just hoping maybe I might get lucky. Thanks all
99 protege clutch headaches:(
How did you adjust it if it's hydraulic?1990 Protege 4WD
1 3 5
2 4 R
Pedal adjustment more then likely92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Adjustment
Originally posted by me109 View PostHow did you adjust it if it's hydraulic?
Oh right. I always forget that one.
Sounds like there may be something wrong with the fork. Unless you got the wrong slave cylinder, but that seems unlikely.1990 Protege 4WD
1 3 5
2 4 R
Figured it out It's not good!
