I cannot find the answer to the squealing belts on my 1997 Mazda Protoge. I had new belts put on but they still squeal. What's the answer?
Squealing belts
Not enough tension, bent pulley, and partially seized alternator bearing come to mind.1990 Protege 4WD
likely more tension is needed.
an old trick is to run a bar of soap on the contact surface of the belt.
it serves to multipurpose. both cleaning & aiding in traction.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
