when i type in "radio trim" i get over 300 possible threads! what gives? I tried advanced search which only brings up threads that have NOTHING to do with radio trim. Both of my proteges are old with alot of miles and i would like to use this site to help me work on them...but i can't figure out the search system...making it useless to me. My current project is trying to remove the trim around the radio of my 95 (automatic) so i can get at the lighter which is not working. The top part pulls free(metal compression clips) but the bottom doesn't...i can't figure out how to remove the trim below this center trim either. Any help would be much appreciated.
Having trouble using the searches.
Use Google to search the site.
site:wihandyman.com <search string>1990 Protege 4WD
